Re: how do i get the factory default setting for canon ir...
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR Then press ok an off the machine wait 1 minute and on the machine..
Copytechnet
https://www.copytechnet.com > ... > Canon
Feb 14, 2014 - This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery. ... Mismatch of serial numbers of three items ...
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode copier / function / clear / err ok.
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. Just a guess. If you have an owner's manual, I would check there to find how to solve the problem. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
