MY AcuRite 00592W2 is reading indoor temp approximately 10 Degreees high (84 should be 74), how can i adjust it into tolerance? Outdoor reading is good.
Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
AcuRitehttps://www.acurite.com > media > manuals > 0...
PDF
NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
That outdoor unit takes batteries and they have to be replaced. When you replace them it is a good idea to bring the unit in the house and be close to the base. They can take up to 20 minutes to start talking to each other. The pressure and indoor temp are inside the display unit. Make sure that there are no other strong radio signals in the house that can interfere with reception.
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Typically the Sensors Sync-Up within 10 to 20 Minutes. However, placement of the Outdoor Sensor is also important. The National Weather Service (NWS) and NOAA measure the Temperature in the Shade, and NOT in the Sun. So be sure that your "Exterior Sensor" is placed in the Shade, under an overhang for example. However, be careful not to place the sensor under an overhang, where there may be a soffit-vent or gable-vent, that is used to vent out warm air from the attic. Even a three (3) season, unheated porch can be warmer than the actual external temperature, due to passive/solar heat captured thru the windows (East/South/West).
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
