okechukwu Abraham Posted on Jun 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta c451 is showing white linen the printed work
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jun 24, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910719
Points
11959
For black and white??? or a color????? Means you might have something blocking the LASER for that color. print out a test chart for each color which one has the white line?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 22, 2008
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Anonymous
  • 3 Answers
  • Posted on Mar 17, 2009
SOURCE: error c3921
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
Anonymous
  • 145 Answers
  • Posted on Mar 18, 2009
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Anonymous
  • Posted on Apr 07, 2010
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
My c451 showing printing status but not picking paper from any of the trays
There could be paper or tape wrapped around the pickup rollers. Also they just may need some cleaning with rubbing alcohol and a Q tip.
My c451 konica minolta printer is show error code 4501
Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
I have c451 giving me heavy cyan background at the edges that suppose to be white after printing. What's the cause and what's the solution pls
First check the Laser window cleanliness,
Then check the IU-Cyan and its charging grid cleanliness.
also try in service mode-Image Processing Adjustment-
Background voltage value can be increased.
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Konica minolta c451 not booting after power on
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
Paper misfeed
828120c7-b2c6-4ef1-86da-8d12eb17847a.jpgkonica minolta c451 printing this type
How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
1helpful
Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
