Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
