My icemaker will only make ice after the reset button is pushed. When you push the reset the icemaker will ding and then one tray of ice will drop then you will hear the water run and then it will ding again. Then if you wait no ice will be made until you hit the reset again. We replaced the icemaker assembly thinking that this would be the right fix, unfortunately no difference.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
