On a regular basis, the F9 notifies the user that it is time to do a clean cycle. Mine no longer seems to do this. I have unplugged the unit and later plugged it in, but still nothing. I was just wondering if there was any way to manually start the clean cycle?
At the time of set up, Jura instructions ask activating the use of Filter cartridges. This eliminates reminders for descaling.
Solution:
Throw away the filter cartridges that are expensive, ineffective & block descaling reminders.
Descale the machine every three months using manual descaling method. See link for instructions. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
SOURCE: cleaning machine propt will not go away
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
SOURCE: clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Maintaining a clean washer helps to ensure that the laundry looks its brightest and smells its freshest.
Follow a few simple strategies on a regular basis, and your washer will produce the results that you want.
Fortunately, most of these cleaning steps are only necessary on an as needed basis. If you prefer, complete most of them once a month for a sparkling clean washing machine. Follow these helpful pointers.
Goog luck.
