Question edited for clarity FULL 'make model (what is is).
Question moved from Cars and Trucks, which also doesn't help identification of the mk 5603 or mk5603!
Best advice right here. Also "the same as the one that is in it".
RepairTJC.comhttps://www.repairtjc.com > Guides Michael Kors use 395 and 371 pretty evenly. We recommend using a quality brand such as Duracell or Renata when replacing the battery of your Michael Kors watch .
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
Hi Josh,
I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off). (OR)Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
Remove the circular watch battery out of the back of the watch.
Take the battery to any department store or watch store and purchase a new replacement battery.
Insert the new battery into the back of the watch.
Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
