Question about Zanussi Refrigerators
Zanussi fridge freezer
Model number ZBB 6286 product number 925 771 741 06 the machine turns off randomly, the pilot light and the internal light n the fridge turn off and the compressor hum stops. i have checked power to the unit , checked plug and fuse and all operating perfectly, other items work in the socken when the fridge does not. it turns on randomly, compressor hums, green pilot turns on and the internal fridge light comes on, it may stay on for an hour or maybe 5 minutes, random. help appreciated
    Master:
  • Zanussi Master
  • 610 Answers
Sounds like a bad solder joint causing intermittent power issues...
Posted on Jun 20, 2016
6ya staff
SOURCE:
How do I get rid of bad smell in the freezer part of my Zanussi fridge freezer ZBB 6286. Pilot light and fast freeze light are flashing.
first cut a potato in half and push it ion the middle of the freezer, it will absorb the airborne bacteria and reduce the smell . leave in freezer for about 2 hours then take out an throw away. next pour bicarbinate of soda into a bowl and put it into the freezer also leave overnight and smell should be gone
Mar 03, 2015 | Zanussi Refrigerators
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
Oct 30, 2013 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi fridge freezer. fridge section not working
Check the relay on that model and also check the pressure on freon and see if its up to specs. It may also be a bad trans board .
Apr 22, 2012 | Sewing Machines
I have a zanussi fridge freezer model no zx56/4w. the fridge door was left open for 10 days now fridge is too warm and freezer is icing up
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
Sep 16, 2010 | Zanussi ZX56 / 4 Bottom Freezer...
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi ZX99 / 5 lights flashing
I have the same problem and cant get to the bottom of it. As you say the fridge is fine and remaining at the temperature that you want it (as does my freezer section of it) and does become extremly annoying after a while.... I would be gratfull if anyone else has a cure for it !
Nov 21, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
59 people viewed this question
Top Zanussi Refrigerators Experts
Felizardo Erilla
Felizardo Erilla
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
