Samsung 55 Inch UA55F8000 Smart Full HD 3D LED Multisystem TV 110-220 VOLTS Logo
Larik S Posted on Jun 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung LED TV UA55F8000AR showing Horizontal Black shadow. Perhaps Backlight LED damaged? What is the problem and how to Fix it?
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on Jun 19, 2016
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1872373
Points
21433
Can be the back light led or the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Samsung led tv UN46EH5300FXZA screen is black with no sound. Will turn on and can see menu when shining a flash light on screen. No visible back light or damage when inspecting boards. Suggestions?
Hi There,
It appears to be a case of backlight failure. It is a common problem with LED TVs. Some of the LEDs in the backlight must have gone bad. It is repairable but needs an expert to do.
Samsung series 5. 5500 LED TV BLACK SCREEN
perhaps the backlight invertor driver circuit.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
See where the wires from the long LED strips on the both sides of the screen lead you to.
does your model have separate board for backlight ? or is it integrated with TCON ?
Samsung LED tv horizontal lines
Your lcd screen itself or the led-backlight matrix of your lcd screen have this problem ( if there was not worked insite the house or room with wallpaper chipping or new wallpaper?), the answer is to get warranty if it is within the warranty-time in most cases its happens by over 4 a 5 years old SAMSUNG (led backlight matrix) lcd tv's ?? or younger have no heard of this problems by the older lcd ccfl lamp backlight devices.
There is usually no thorough repair option for known as it seems in practice
A great hobby capacitor-rolling option to do ?who should know ? if they look bulged or have leaked on some places, but if there where leaking capacitors there can be damaged print circuit lines on some places on the circuit boards to find if it is find by little brown spots under capacitors.
Beware of people watch out for those who want to empty the rack.
Its maybe a new worldwide problem in much cases and the service oft too. turns out.
To read use a add-on translator and read that its one of an little epidemic question.
Radar Toon onderwerp archief Samsung LCD LE 46M87BD
Visio E701I-A3 TV backlight part number
The following picture symptoms indicate a bad LCD panel, and NOT a bad back light or board:
-One side of the picture is darker than the other
-Picture has horizontal line(s)
-A dark, cloudy spot spreads across the picture
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
2answers
Shadow area on LCD screen.
one or more of the led back light lights has probably gone out and there is no way to fix it except to get a new backlight
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
