Question about Powerware Computers & Internet
I have powerware 9120 6kva which indicates charger failure..where charger board is ok..what should i do??
SOURCE:
erwinroyo
  • 189 Answers
SOURCE: Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Posted on Nov 06, 2008
  • 195 Answers
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 2246 Answers
SOURCE: I ave a powerware 9120 and get a Charger failure
check your batery, may it was leaked, change it with new battery
Posted on Jan 17, 2011
SOURCE: powerware 9120 6000i 6kVA ups indicates a charger
M-PW9120 6000i protection diode is damage when we connect the ups with main source otherwise backup is ok only protetion diode is damage
Posted on Mar 05, 2011
chowdhuryemr
SOURCE: Powerware 9120 6000i model indicates
I have facing problem of "Bus Unbalance". Now UPS running on bypass mode. Can I reset our UPS without failure the output. We are using Powerware, model PN91206000i
Posted on Jun 06, 2012
What does message :a #alarm 199: "batteries disconnected" means, and how to resolve this problem? thank's!
The charger board has failure. Model already obsolete. Propose to buy a new unit
Aug 23, 2013 | Powerware 9120 UPS System
Bc bus fault of 9120 2KVA
Suspect charger board failure. Replace with new model 9130. 9120 is obselete
Mar 21, 2013 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
Jan 17, 2011 | Powerware 9120 UPS System
Is the fuse in a powerware 9135 user replaceble
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
www.eaton.com/9135
Jan 05, 2011 | Eaton Powerware 9135 UPS (700465446) UPS...
Powerware 9120
Greetings!
Thanks.
Nov 06, 2008 | Computers & Internet
Powerware 9330
your problem could be related to a dispay board or possible CSB board.
Sep 24, 2008 | Powerware Invensys 9330 Model 40 UPS...
Pw9120-6000
1st, the 9120 is a 700, 1000, 1500, 2000, 3000, 5000 or 6000 Va
if it is a 6000 Va that voltage sounds ok, and the ups as no problem, each battery will be around 12,75 Volts, it will be higher and the charging circle ends.
Jun 27, 2008 | Powerware 9120 UPS System
Computers & Internet Logo
249 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
