SOURCE: scrambled keyboard
Is it giving you numbers and symbols?
do this:
Press and hold the function key fn while pressing the num lock key num lk .
This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp pavilion 9000 gets scrambled screen and fails
Sounds like a driver problem. Make sure you have all the updates. If the problem started after a recent update, a driver rollback may be needed.
If it is not the driver, then it might be a setting in the way your laptop handles video. Go into your ATI or nvidia setting under control panel. Review all of your setting and make sure nothing unusual is set, or find a 'restore to defaults' button if it has one.
SOURCE: HP Pavillion DV2750 Laptop Scrambled screen
Hi there!
Can you remember what happened when this started? Were you trying to update the driver for your graphics card? Or did it just happen on its own?
Have you tried booting into Safe Mode yet? I assume your operating system is a version of Windows.
To boot into safe mode, press F8 repeatedly, every second or two during boot. If you can reach the Safe Mode options screen, select "Safe Mode" and press enter.
If the machine boots into Safe Mode and displays video correctly, go into Device Manager and uninstall the driver for your graphics card. To do this:
1. Click Start
2. Click Run
3. Type: devmgmt.msc
4. Expand Display Adapters
5. Right-click the graphics card and select "Uninstall"
Once that process is complete, restart the laptop and observe the behavior of the video. If the problem persists, its source may be more complicated and related to hardware.
If the BIOS flash screen is skewed from the get-go, I suggest you contact HP Support for more guided assistance. You can also check the warranty status of your laptop HERE. If the warranty is still in effect, you should be able to fix the laptop without a single cost to you.
If the warranty is no longer in effect, the fix for this may cost you.
I hope this helps! Feel free to respond if you have any further questions.
Testimonial: "THE UNIT IS OK NOW.. the problem is the videocard driver... thanks a lot"
SOURCE: Lenovo G550 (2958-ACU) the display is scrambled/folded
Your computer uses Onboard graphics(Intel Graphics Media Accelerator (GMA) 4500MHD) which means the GPU is embedded into the motherboard. The problem is most likely to be the GPU as you have predicted. If your laptop is under warranty you should push for a replacement as opening it will void your warranty. However if its out of warranty then you will need to remove the keyboard to access it. Check for bad connectors from the video card. Unplug the connectors wipe them with a cloth and then plug them back in. Power up and see if it resolves the issue.
NOTE: TO AVOID DAMAGING THE BOARD COMPONENTS WITH ESD AN ESD WRIST STRAP IS MANDATORY FOR THIS FIX .
Hope this helps,
Sai.
SOURCE: my screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
