If it is a mechanical machine, you can apply 1-2 drops of good quality sewing machine oil or liquid Tri-Flow Synthetic Lube to any place where metal rubs against metal. AVOID belts, plastic gears, etc. Be sure to also move stitch selector lever and dial mechanisms.
The one thing on a sewing machine that needs the most repair work is the belt. The sewing machine belt is a piece of rubber that makes the wheel turn and the needle go up and down in a sewing motion. If the belt is in bad shape, the sewing machine will not work. Sometimes while sewing you may notice a burnt rubber smell. When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; just make sure you have the proper belt.
On a treadle sewing machine usually there is no adjustment on the tightness of the belt so you have to shorten it. There will be a metal clip holding the belt together and you can remove and cut the belt shorter and then put it back together. Be very careful to not cut too much off. Probably be a good idea to trim it a very little at a time.
If I recall correctly, to fill a bobbin you must first release the belt from the wheel by loosening the knob on the small machine wheel. Then after the bobbin is filled you need to tighten that knob again. Do you have the manual?
to change the belt of your machine, just lossen the bolt where the belt put in. if you do not know how to do it, go to the sewing machine store and asked for assistance to change the belt of your machine.
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
