Watches Logo
A
Anonymous Posted on Jun 18, 2016
Wont to no what size batteres my big tic jr.7845 use. Lost the ones came out if it.
1 Related Answer
Anonymous
  • Posted on Apr 17, 2010
SOURCE: I want to change the batteries on afossil big tic
i think it pretty much pulls right out, the kid at walmart did it rather quickly.
Which battery does a Fossil Big Tic JR-9779 (Chinese Dragon)watch take
Fossil Watch Battery Replacement - Ultimate Size Guide -
batterymole.com https://batterymole.com > fossil-watch-battery-replace...
Aug 21, 2022 - The CR2430 battery is a 3v lithium battery, see the shape below. This example is made by Renata, but you can also get the produced by Duracell, ...
FOSSIL BIG TIC JR 8199. What type of battery does it use?
392, also known as SR41W
Possibly two, as display is usually powered separately from time movement.
Need owners manual for fossil Big Tic Blue JR 8624
Inside the case back on my JR-7855 is a label with the steps to take to change the batteries. The sticker says to short the pad marked "S1" with the pad marked "+". Keep doing it quickly, then check the watch facelb_icon1.png. You got it right when the seconds start to change on the face.
Here is a view at the inside of the watch. The two points you are looking for are highlighted in red.
Ads by Google
Apr 02, 2014 • Watches
FOSSIL BIG TIC JR-7849
Use tweesters to touch both "+" and "s2" point can change that.
1helpful
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
1helpful
2answers
I have a BIG TIC JR-8529. Is this model obsolete? The watch was not working properly (stopping/slowing down), so I replaced the battery. It seems fine now, but still no digital display in the background...
Since Fossil do not list their instructions under model numbers it is difficult to be sure that you rmodel still exists but if you go to their web site for instructions http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
(click on this link to go there) and you will see some instructions for various big tic watches and you can select the one that suits yours.
The only one that I could find that had a single button above the winder used it to cahnge the colour. Pressing this button for 2 seconds will change the colour to "alternating" and the same again will produce a fixed colour. Perhaps this will make the change of display you need.
Often with watches, you need to use a pair of tweezers to short the battery case to the chassis ((often marked "ac"). This seems to be a re-set function, although I have never found an explanation for the need to do this.
If all else fails, look up their contact details and speak to them about your problem.
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
