Depth adjustment will not turn. Gun is new and drives brads. The adjustment knob turned once but now will not turn at all. What am I missing? The "manual" that was included with the driver offers no help at all.
SOURCE: Describe your NT50AE2 2" Brad
Hi Randy,
Welcome to fixya!
Copy and paste this web address into your browser and a webpage will open with your nailer on it: http://www.hitachipowertools.ca/en/Products?cat=29&pid=254
Scroll down the page to the bottom of the description and you will see the owner's manual listed. Click on that and you can download and print a copy.
Please place a vote when you accept this solution. Thanks,
Handie Andie
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
