Question about Hitachi Heating & Cooling
How do i fix my hitachi air condition remote control
After changing the batteries of my hitachi ac remote,the screen only shows the number 1 and if i change the temporature with the temp button it only goes to numer 2 and 3.the fan button not responsing.the ac is working in something like auto. I press the reset button with same result and take off the batteries with no success.any suggestions?
SOURCE:
hapndnvegas
  • 35 Answers
SOURCE: air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Posted on Apr 14, 2008
bobotfel
  • 237 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 958 Answers
SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Posted on Jun 24, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
  • 634 Answers
SOURCE: fujitsu air conditioning remote control not
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Posted on Jul 07, 2009
Changing the input on a hitachi tv without the remote
well if I knew the model number could possibly tell you eactly where it is located , as I do have over a hundred manuals for hitachi products , but anyways look on bottom edge of screen there should be five buttons one of these hould be labeled source , this is the button you want to press , it may take severl presses to get the input you like and the display will show in green what input its on
Jan 06, 2017 | Hitachi Televison & Video
Hello sir, my hitachi ac's model name (HITACHI SAC 1.5 ZUNOH 3200f RAU318AWD) it's remote botton is not responding. I have changed it's battary but still remote is not responding on pressing botton.
I see the remote is a wireless one. It may need to be "paired" with the A.C. This is often done by holding down a button on the remote whilst powering up the controlled device.
You'll need to check your manual or contact Hitachi to be certain.
May 23, 2016 | Hitachi Televison & Video
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Does anyone know what's going on?
Unfortunately the bandwidths of remotes often crossover. You can put tape over the ir sensor on the ac.
May 21, 2012 | Haier Heating & Cooling
Hitachi AC's remote control sensor not working
Hitachi AC's are now made with "bovine ***** material" quality. we have two brand new AC's neither is working now. Remotes are not sensing at all. Hitachi is "bovine ***** matter" now.
Apr 05, 2012 | Heating & Cooling
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
My hitachi split ac is not starting, orange light is blinking........ no response on clicking all the buttons in remote
this problem arises when u disturbe the remote settings. to make it operate again use the following procedure
1.on the power from stablizer
2.press the button in remote with 'key' sign once
3.now adjust the number displayed in remote 9 99 to 3 25 by using 'down '(temp adjustment button) key.
4.press again the button with 'key' sign
5.now ur ac is reinstate
enjoy the breeeeeeeeezzzzzzzzzzzzzzzzeeeeeeeeeeeeee
thanks
atul sharma bikaner rajasthan india
May 05, 2011 | Hitachi Heating & Cooling
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Heating & Cooling Logo
1,222 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
Marvin
Marvin
tony_tc1
Level 1 Expert
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
