Worked ok for about 1 yr. Yesterday, temp went out. changed batteries,& followed trouble shooting,no luck
SOURCE: compaq presario 158793-001 motherboard
I have a compaq 1247 laptop. I had problems after I took it apart. It was very difficult to get the processor chip back in properly, the little clip has to "snap" in place to hold the chip firmly in the socket. That solved my problem.
SOURCE: changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
SOURCE: My harmony H659 just went down
I took it in to Best Buy and the Geeks informed me that it was dead. I purchased a new remote. Thankyou.
SOURCE: My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
SOURCE: MY RCA JUST STOPPED TONIGHT,WENT TROUGH ALL THE
This sounds like a power supply problem. This is usually caused by dried out capacitors on the power supply board. If you open up the TV try to look for capacitors that appear to be bloated or puffy on the top. Some of them may have even exploded. I would however suggest that you have a TV technician examine this TV and repair it. This is because it requires specialized equipment to do the job properly.
I hope this Helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
