My toyota has JBL so I am using the Metra 70-8113 wiring harness. On Metra there is Red connects to Red on wiring harness of Sony MEX-N5100BT Yellow connects to Yellow Blue connects to Blue Blue/White connects to Blue/White Black connects to Black Black/White connects to Black/White There is Solid Blue which is not on Sony MEX-N5100BT Where should I connect that? On Sony MEX-N5100BT wiring harness There are many besides above green , green/black, purple, purple/black, white, gray white and white/black which i am not sure where to connect. Also How would i check the wires are actually getting current.
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
