I would suggest unplugging the oven for at least 15 minutes to see if it will reset itself.
Is this oven programmable when the door is open? If not, you might want to check the door switches to make sure they are functioning properly before considering a control panel replacement. Also make sure the oven is plugged into a grounded outlet that is actually grounded.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
SOURCE: What would cause the touch
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it
back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
SOURCE: maytag mmv5000bdw Touch panel works intermittently
If nothing works, it sounds like you didn't get the cable inserted properly. It should fit into a connector which carries signals to the microwave's control components. These connectors usually pullup, you insert the cable, and push the connector back down.
Testimonial: "Fixya is a great resource!"
SOURCE: LG LMVM2075 Microwave Control panel does not work
The keypad has failed and it is available as a part of a new outer door panel,
whose part number is 383EW1A130E for $103.19 plus shipping.
You can get it from Encompass here
or you can call them toll-free at 866-779-5835.
For disassembly info, you can see the service manual at our site:
http://www.microwavedisplay.com/lmvm2075sb_sw_sm.pdf
It does not contain part numbers, so you will need to contact Encompass.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe
the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out
of the controls and door panels.
