SOURCE: torque settings for big ends on a 97 toyota camry 220sei
On the V-6 it's 25 Nm (18 ft lbs) on the first pull and then you rotate the next pull 90 degrees using a torque angle wrench.
Checking the specifications for the four cylinder:
25 Nm (18 ft lbs) on first pull and 90 degrees
on the second pull using a torque angle wrench.
The check engine light is telling you that a fault has been detected in the systems that the cpu monitors. With the gears not changing to over drive I would guess that the fault would be a solenoid for overdrive has failed. Have the fault codes read
run the fault codes and look for low pressure in the fuel system. failing fuel pump
