Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? what is the operating system of your computer. Is it windows - deleted files will in be recycle bin. is it apple - trash can holds deleted files restore files from these areas of the laptopHi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Just open windows explorer. Find your flash drive on the list under the
"My Computer" heading. Then go up to the Edit tab on the top left of the
screen and click on it. Choose "Select all". Now hit the shift and the
delete keys at the same time and all the files on your flash drive will
be deleted..
depending on what sort of stuff this is
if its related to the operating system deleting these files might effect the operating system making it unstable
other than that just select these files right click select delete
hope this helps
try pressing the unlock button if u have 1 and remeber what button you pressed or play around with it but not too much or cant unlock it or take it to an elctronic store and ask im12yrs old i kno this kind of stuff
Delete wlm by going into the control panel and opening the add/remove programs and uninstall Windows Live Meeting. About the rest im not sure as i have not run vista yet. At least this will help you some
Simply buying the external hard drive is one thing. Did you simply plug it in, copy stuff over, or _move_ stuff over? You have to move stuff over in one spot to make room elsewhere. Cut-and-paste is your friend. Do not move programs this way -- just data, like videos, music, photos and word processing documents.
There's a wonderful program called ATF-Cleaner from http://www.atribune.org that can also search your computer for unused files. (Windows has a built-in program, too: click Start: Accessories: System Tools: Disk Cleanup). But the ATF-Cleaner is a bit more thorough, does more stuff. You may be simply wasting a surprising amount of hard drive space on stuff like temporary files that became pretty much permanent. You can also free up some space by deleting old System Restore files and the clike -- look through Disk Cleanup.
you go in to my computer look for the E drive click on that drive and all of ur songs and folders will come up and then u click on wat u want to delete and the click on delete
