Sharp Notevision Xr-10s - Dlp Projector - 2000 Ansi Lumens Logo
Scott Ingram Posted on Jun 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sharp Notevision XR-10S Projector with Key Lock on but I do not have the remote. How can I unlock them?
  • Scott Ingram
    Scott Ingram Jun 16, 2016
    After scouting the Internet to find a non-subscription version of the owner manual... Simply hold down the enter button for 5 seconds... Worked perfectly.
Electro Med Services
Level 3:
  • Sharp Master 6,694 Answers
  • Posted on Jun 16, 2016
Sharp Master
Level 3:
Answers
6694
Questions
Helped
1872514
Points
21433
Its not possible without remote.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
I have a Sharp Notevision XR-50S Projector with system Lock on but I do not have the remote. How can I unlock them?
  1. Power Off: First, make sure the projector is powered off.
  2. Control Panel: On the projector itself, locate the control panel with buttons. You should find buttons like "Menu," "Enter," "Up," "Down," "Left," and "Right."
  3. Access Menu: Power on the projector and press the "Menu" button on the control panel. This should display the on-screen menu.
  4. Navigate Menu: Use the arrow buttons (Up, Down, Left, Right) to navigate through the menu options until you find the "System" or "Settings" menu.
  5. Unlock: Within the System or Settings menu, look for an option related to the system lock or security settings. Use the arrow buttons to select it.
  6. Disable Lock: Once you've highlighted the lock option, press the "Enter" or "OK" button to access its settings. You may need to enter a password if it's set, so try default passwords like "0000" or "1234." If none work, you might need to contact Sharp support for a password reset procedure.
  7. Unlock: After accessing the lock settings, disable or unlock the system lock.
  8. Exit Menu: Exit the menu by pressing the "Menu" button again.
  9. Test: Power off the projector and then power it back on to see if the system lock has been successfully removed.
My sharp PG 10s Notevision comes on. However, is not projecting my computer images on the screen
Make sure the connection from the pc to the projector is secure, also make sure the display settings on the computer are set to extend the desktop onto the projector, and that the projector is set to pc mode.
3helpful
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
14helpful
2answers
1helpful
VIDEO DISPLAY PROBLEM FROM SHARP XR-1S LCD PROJECTOR
make sure the resolutions match. change it on the projector.
1helpful
2answers
Sharp xr-10s /sharp xr 10sl are they the same unit?
Hey, XR10S and XR10SL is the same. The Lamp is SHP93 if for Replacement.
Sharp Notevision XR-10S Multimedia Projector shows pink on the screen
Hi there
If the colour only shows pink when a source ( i.e. vga or video ) is inserted. Firstly check for a faulty cable - 99% it is the problem. Otherwise you'll have to take it to a repairer as the input could be damaged.
1helpful
Manual
http://www.sharp-world.com/products/data_projector/xgmb65xl/pdf/XGMB65XL_XR10XL_ex1_en.pdf
2answers
Projector
I have a Notevision Sharp xr-1s projector and it wont work with my windows vista laptop. I tried it on my vista pc and xp laptop and it works fine.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
