Dont light. Is possible a setting fault or must changing a control panel?
This is for a Saeco Incanto Deluxe....
"doesn't power on"
If the control panel doesn't come on, check 2 things first.
1. Is the unit plugged in to an working outlet?
2. is the switch on the back turned to the on position?
OK, if you checked both things and are sure, you can check the breakers (switches, fuse?) on the unit. unplug the unit. empty the unit out (water, beans, drip tray, steamer knob, etc) remove the water tank and put the unit on its side there are two screws on the bottom of the unit, they are torq head and if the unit is on its side, they will be in the middle top and middle bottom. they are used to hold little plastic covers. Once the screws are taken out, remove the little plastic covers. once they are removed, shine a light up them, one side will have 2 tan reset switches, the reset button stick out between two wires. i had to use a butter knife to get to them. press them both in. Put the machine upright, plug it back in, and see if it turn on.
if this process doesn't fix the unit, put it back on the side and try to put the resets back in. they can be tricky.
Getting anymore into the unit can result in you making things worse and you should have a trained tech look at it.
also, the wiring diagram on this unit is written in Italian.
breaker switch fuse
