Computers & Internet Logo
Ok Posted on Jun 14, 2016
Asus x553m laptop wont turn on fully?
It still charges fine and it will bring up the logo and load, but then the screen showings black (its still on - it doesnt turn off) and it wont load the windows after or boot up properly, just stays on the black lit up screen. and I cant locate where the battery is so i cant take it out and hold the power button or anything. Need help please!!
5 Related Answers
DENNIS MITCHELL
  • 1003 Answers
  • Posted on Jan 15, 2008
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Anonymous
  • 344 Answers
  • Posted on Jul 03, 2008
SOURCE: ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: my iphone wont go past the apple logo
hi juli this is glady even i faced the same prob in my i phone to so download a new firmware from apple site nd then switch off ur cell while conectd to ur pc then switch on through ur apple pc suite upgrde ur phone through the i tunes o give the path nd see or better to go to youtube for more crystal clear info bye
Anonymous
  • 56 Answers
  • Posted on Oct 15, 2010
SOURCE: My HP Pavillion laptop g61 wont turn on or off.
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Yogger
Max Quido
  • 117 Answers
  • Posted on Dec 02, 2010
SOURCE: my symbol mc50 scanner wont
it is possible that if you changed the battery you forfot to move the slide button next to the battery to the correct position. It often happens to me :-) Please check it, its on the right top corner of the battery, you should not see the red marking, if there is the correct position.
Asus x553m motherboard no disply
Get it repaired in repair shop? OR.....
Asus x553m this is Notebook not a motherboard,
power pack AC attached both ends,? not wrong pack?
main battery removed FIRST. they short, and overload the DC power system inside. the battery on this PC is BURIED DEEP.
remove the center power plug on battery , as seen in video.
vid frame 4:15, SEE?
screen 100% black, ever shows any text ever or Asus Logo ever.
100% black?
does the fan run inside, are all vents clean, so it can not overheat
https://www.youtube.com/watch?v=wgEEMRg_OJs
the cables break easy if not up to doing this with no damage,
don't.
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
2answers
Just got it new.....screen won't go past rca logo
Why wont my rca tablet load past the RCA logo screen? - I ...
www.askmefast.com > Consumer Electronics > TVs > Tablet
Laptops & Notebooks .... My rca tablet wont go past the first logo screen and i have factory reset it and ... Some how the factor reset button on the back of my rca 7in tabletgot pushed and ..... Rca tablet will not play games it just goes back to home screen ....My rca 7 tablet is stuck at the main screen and it won t go any further.
my rca tablet won't turn on I tried charging but it's not working ...
www.tomsguide.com/forum/id.../rca-tablet-turn-charging-working.html
Dec 15, 2015 - 12 posts - ‎10 authors
My rca tablet isn't working I tried charging it but it's still not turning on ... Hold them both in this position until you get a menu on the screen. .... I've repeated this attempt to turnit on it just flashes on the battery logo with an exclamation point ... SolvedMy Asuslaptop model Q551L won't turn on or charge what ... Tablet keeps turning off - Battery
Nov 16, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
RCA tablet no power-up - Power Up
Mar 30, 2015
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Hii my asus vivobook laptop is charged for several hours but it wont turn on showing black screen plzzz hel me anyone
Are there any lights on the laptop blinking when you try and turn on the laptop?
You could have a bad battery.
Have you tried leaving the charging cord plugged in and turning on the device to see if it works?
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
My asus eeebook boots up fine, shows asus logo but THEN THE SCREEN goes black
Windows is "crashing", and then automatically restarting, over and over.
Reinstall the operating system.
Laptop Screen Issue
try to turn it on with the battery out, as it could be a faulty battery, if you still get nothing take it back to the store as it has a fault.
My computer cant detect my iphone4 when its plugged in and it wont turn on or charge
Once you upgrade the firmware. You can not go back. To bring the phone back at least from black screen. You have to keep trying to reboot in dfu mode.I am assuming you jail broke your phone, so you might have to use that software to bring it back up with that.Good Luck
When i turn notebook on it wont load windows to start up
Reboot your computer and at the ASUS logo hit f8 this will bring you to a black screen with some different options. Arrow down to the option that says restore computer to last known good configuration and hit enter. It will bring up a list of dates, choose the one that is closest to the date that you knew your computer was working fine. It will then reboot and if all is good you will boot into windows. If this doesnt work, let me know and we will take a different approach. Thanks!
Lori
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
