Auto Adjustment keeps erratically blinking on and off. When Auto Adjustment is Locked, then a window that states Auto Adjustment is locked erratically blinks on and off
Hold menu button for 5-6 sec.
Enable od disable this funnction.
I clamped the third button (with the return bent arrow key). This works. However, when the display goes dark for a second and repeats in several seconds, I press the menu or two buttons at the same time, and hold them down for a few seconds, the display seems to work OK for a long time. When I shut down the monitor, I turn the power off to it and leave the third button clamped.
Is the driver installed for it?
If not here it is:
http://www.samsung.com/us/function/search/resultList.do?searchWord=731N
Hold down the menu key for 5 seconds!
Go to an services and change the buttons from the control panel. There is the problem. it happened to me. I have changed and no longer perform. Good luck
Hey guess i came along the same problem but got it fixed after the following steps.
Problem solved: Monitor was within Warranty and Samsung sent me a new monitor.
Thanks for all of the input
Mololkai
NOTHING TO DO WITH DRIVER.INSIDE IS A FLASH 25FV01 WICH IS BLOCKED.GO WITH THE 720N TO SERVICE.
I have the same problem, only with the Samsung 720n monitor. Accept the monitor buttons hardly work at all, so holding a key wont help. Can anyone tell me what I can do to fix it, because I understand that installing a driver might not be the solution.
Kick the poo out the door, throw a hissy, Stomp around a bit, Go to the store, buy another POS that will be jacked up in 6 months, be happy for that time, then start all over again.
Well, that is what I think that I am going to do.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
for Tom19511: confirmed driver is installed and no matter what resolution changes made the monitor responed with the same blink on and off small window in the center of the screen whether in Auto Adjustment or Auto Adjustment Locked.
Thanks for your input
Molokai
I have the same problem. I blinks a small window right in the middle of the screen that says "auto adjustment locked". There doesn't seem to be any rhyme or reason as to how often or when it blinks. It seems to be totally random. Can't get it to go away. Now it has started shutting off randomly as well.
This just started a few weeks after I got my new computer. I have downloaded the latest driver. I use Vista with NVIDIA GeForce 8600 GT.
It is making me nuts.
Same problem. Can't fix. Downloaded driver. No help. I pressed down the
menu key (1st left) and wedged small piece cardboard to hold that key
down and that's the only way I have stopped that annoying menu from popping up in the middle of my screen.
I have tried all the suggestions presented but nothing stops these annoying SyncMaster Magic Bright Automatic monitor settings adjustment boxes from flashing on my screen. The only relief I can get is when I manually hold the settings button down so that I can see. The image/picture with this monitor is fantastic but I will never purchase another Syncmaster or monitor with automatic settings.
hold down the MENU BUTTON for 5 seconds, it enables/disables that function :)
hold down MENU BUTTON, it enables/disables lock function :)
hold down MENU BUTTON, it enables/disables LOCK FUNCTION
I have a problem too.yesterday, my menu appeared and disappeared 10 times per minute. without touching anything. now.... my 720N is calm. no manu at all. the menu key shows entertain, custom, etc ... and the auto adjustment is loked. now I want to keep pressing 5 seconds the menu key, but .. nothing.the second key, works normally . but menu, and auto adjust........NO. PLEASE GIVE ME A CLUE .....
ok My Emachines menu keeps flashing on my monitor and it is driving me nuts. I can push button and it goes away for a few seconds then starts flashing again.. I have looked everywhere and cant find a solution. HELP
my screen is blue and i cant adjust it because auto adjustment is locked, how do i auto adjust it or change it from blue back to the original white.
Same Same, auto adjust over and over, I held the menu down and waited and released, everytime it auto adjusts. And then starts the mess all over again. I have not had this for very long, and it looks to me that many people haveing the same problem. Anyone, HELP.......
hold your monitors menu button for 5 seconds to lock and unlock.
hold the monitor's menu button for 5 seconds to lock or unlock.
