Try replacing battery (ies) sounds like this might be the issue. If it was working then stopped it would probably be the charge running down. With all kinds of electrically powered devices that have rechatgeable batteried folk do not realise that they have to be replaced occasionally, especially if the device is subject to heavy use.
The sign that a battery needs replacement is that it indicates that it has received a full charge but, almost immediately, runs don when when put into service. Had the same problem with my drill / drive 2 hours ago, need a new battery even though fully charged it does not rotate.
GOOD LUCK
Jamie, sounds like a bad battery, try and recharge battery. You may have to find a small electronics shop to check battery and charger to verify if they are any good.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
SOURCE: I need instructions for gator. only goes in reverse
You need a forward/reverse switch.
http://www.rungreen.com/ForwardReverse-Switch-for-Peg-Perego-12V-Toys_p_47.html
SOURCE: No 1st or Reverse, but will go in 2nd
I just bought one for kids for christmas. Out of the box the switch was already installed. Only worked in 2nd gear. I pulled switch and it only hooks up one direction. Under dump bed theres a cover that lifts up and 2 wires goin to each wheel. The wires to the right wheel were unhooked. As soon as i hooked them up 1st and reverse started working. Dont know if this is the case for yours but worth a try.
