Cars & Trucks Logo
Kevin Herrera Posted on Jun 12, 2016
I need help with a code 12 for. 95 grand Cherokee orvis 5.2l. In need of some help. I know what the code says, but don't understand what it means.
I've gotten a code 12 on my 95 grand Cherokee orvis. I've read that it means the battery or power to the ECM disconnected in the last 50 key cycles. I don't know what that means exactly. Any help?
The battery was disconnected with in 50 time of turning car on the code will reset itself after 50 time turning car on nothing to worry about. All it means is computer has no memory
Anyone know where I can find a key fob for my 1995 Jeep Grand Cherokee Orvis, preferably free?
goggle finds that. use it.
1st hit, my lucky day?
http://www.wesellmore4less.com/JEEP.html
http://www.fixya.com/answer/answerpageslideview.aspx?thid=24032635&ctg=231&brd=mine
lots more.
and can very by Country.
country not stated to I guessed.
Jeep exports cars, dont you know.
What is the belt routing on a 1995 Jeep Grand Cherokee Orvis Edition with a 5.2 litre with A/C
This should do it. Let me know if it doesn't look right.
Its from the Gates Belt book.
1helpful
2answers
When turning my 1995 jeep grand cherokee orvis the steering wheel has a wineing noise turning it from right to left. Also there is a wineing noise by the belts behind the radiator. I have a leak in the...
This is most likely the power steering pump that you hear. Check the fluid level to be sure it is full. If the fluid is full then the pump is going out. Hope this helps. Good luck.
I have a Jeep Grand Cherokee Orvis (1991). My
Thank you for your email. I went elsewhere and found satisfaction without having to explain further. The reason I did was because the reply I got from you was not very nice. I didn't really appreciate the attitude. Sorry.
Juanita Barnes
2helpful
Speedometer does not always work 95 cherokee orvis need help
Sounds like the speedo sensor needs to be replace on the transmission. I've had a similar problem with my Jeep with the sopeedo not working then work after the tranny heats up then after a period of time the needle started to jump when at 100 km or 60 mph. I changed the sensor and the problem went away. Good luck!
Speedometer does not always work HELP 1995 jeep cherokee orvis
The vehicle speed sensor and speedometer are one in the same on this model I believe. If one goes out it takes the other with it if its all electronic and not cable driven.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
