On most VTech phones the voicemail indicator turns on when someone leaves a message on the voicemail system offered by your phone company. Many phone companies have such a system, which takes messages when your phone is busy. You'll have to contact your phone company for instructions on accessing their voicemail system.
The message light has 2 functions 1 voicemail message 2 to indicate someone has rung you (internally they then press the MESSAGE button on there phone) To clear this Lift the handset and press the Message light - you must wait for an answer (there may be more than one call to clear Failing this you can clear the local info on your phone - Depending on what system you have Dial 790 or Dial *790
There is no History button that I know of ~ on the system...
But - the message waiting indicator is not working?
Ok, try this to fix the message waiting... leave a voicemail for yourself or get someone to leave a message. FEATURE 1 and your extension...
-> if the light is Not flashing try FEATURE #806 this shuts off static time and date, for some reason this can shut off the message waiting indicator.
Hi, This error indicates a carriage error
Check that the encoder strip ( the plastic strip that rungs behind the
carriage ) is securely attached at both ends.If not, see if it has been
broken, or if not just re-attach ih it onto the fixing lug
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
Thanks for the opportunity to help with your problem. If you also have voice mail through your phone service provider, it's possible that while you are on the phone, the incoming call is "waiting" (meaning you are hearing a beep while you are still talking assuming you have call waiting). If you don't pick up the incoming call, your caller will hear your "voice mail" message and leave a message. However, your answering machine will not indicate that you have a message.
If my assistance was of any benefit whatsoever, please give me a rating so I can continue to improve my service. Thanks for using FixYa.com.
