Rollewd over on remote proscan in volume and cable gone only flashing colors screen
Try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: problem connecting cable wires for Sony PFM-42B2 42 in. Plasma TV
This is a monitor, not a TV. You need a VGA, SVideo or composite connection for video. There are S-video modulators to convert your RCA signal to S-video. About $30 at Radio Shack or Best Buy.The audio is pass through only. You must have external speakers with an outside power source. If you don't have an amplifier for outside audio you can use a cheap set of computer speakers.
SOURCE: My Proscan 50" LED TV (plded5066a-c) is stuck on
Main system control memory IC fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.
