Hisense 55 2160p LED Ultra HDTV Class 4K Smart TV WiFi Television 55T880UW Logo
Tuning my Hisense 55 inch TV bloom-in thing is fine one minute then channels drop out 9 is the worse offender. Spend hours have put in line boosters new Ariel line digital Arial
Keep loosing channels
5 Related Answers
Anonymous
  • Posted on Dec 31, 2009
SOURCE: how to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Sep 03, 2011
SOURCE: I have a 22 inch
hi,
Its sounds like the LCD pannel driver ic faulty. In lcd tvs bellow 32 inches this ic is integrated to (part of) the lcd pannel. In 32 inches or above this is a separate circuit board name T-Con board. In your one it is on the pannel itself. There is no repair possible with this. This ics drives the pixels on the LCD screen. To repair the same You have to replace the lcd pannel. The LCD pannel is the most costly part in an LCD tv. Also it will be available only from the authorised servicing center for the Hisense. Its Better to go for a new tv than reparing it.
OK
gopakumarg43
  • 76851 Answers
  • Posted on Sep 23, 2012
SOURCE: New Hisense 55 inch LED TV does not have volume
Check its speaker. If it found OK, check and replace the audio output circuit board.
Anonymous
  • 760 Answers
  • Posted on Mar 20, 2013
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Harrie
  • 6746 Answers
  • Posted on Feb 16, 2015
SOURCE: My Hisense 50 inch smart screen has picture and sound but both keep going in and out every few minutes....i just bought this TV from walmart not even a week ago
Go back to Walmart this must be a warranty issue.
1helpful
3answers
Light blinking on and off button. Hisense 55 inch,,, model no.50r6e3
A blinking red light on the power button of a Hisense 55 inch model 50R6E3 TV could indicate a problem with the TV's power supply. It could be caused by a malfunctioning component, such as a blown fuse or failed capacitor, or it could be an indication that the TV is overheating. In some cases, a blinking red light can also indicate that the TV's firmware is not up to date and needs to be updated
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
1helpful
How to set up a hisense tv to watch all the channels
Normally you have to go to menu, then something like tuning for digital recievers, then select auto tune. The tv should then try to find all the available channels, note this will take several minutes
2answers
How do i reset my hisense tv without a remote model HSLC4229HDIP it won't show channels
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
To do a factory reset, you should have a remote control.
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
1helpful
2answers
HSL4229HDIP 42 inch LCD intermittent lip sync problem
Hi
Try Buying a aerial with a booster, u can purchase a inline booster at dicksmith or most large electrical stores.
kinds regards Kyle
u can reach me at
[email protected]
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
