Cook indicator light is not getting on
SOURCE: Rice Cooker Instructions
For Queenmom and anyone else looking for the manual for a Black and Decker Flavor Scenter Handy Steamer Users Manual, I just stumbled across one. Here's the link:
http://useandcaremanuals.com/pdf/HS90038.pdf
I hope that helps.
SOURCE: ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
SOURCE: Does my Aroma rice cooker have a fuse?
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
heatman101
SOURCE: how do i cook rice in my rice cooker? what are th...
Just read these ratio's in "The Asian diet". 3 cups water to 1 cup rice. PERFECT!!
SOURCE: Aroma rice cooker ARC 978 - all control panel
Unplug the rice cooker and the remove the cooker kettle. Push the steel button in the center of the rice cooker to loosen the spring. Plug the rice cooker without the kettle, the cook function must not be functioning. Plug it again with the kettle and push the cook switch to see if it working properly.
Here
is a tip that will help you figure out about using a rice
cooker...
How
heatman101
