Question about Frigidaire Dryers
When I turn my dryer on it gets warm,An runs for about 10 minutes or so then it kicks off and a code e61 comes up and it goes off
I just need to know what this code means
  • Frigidaire Master
  • 12,731 Answers
SOURCE:
How do I get my code 61 off and get dryer to work again
A used dryer normally runs between 50 to 75 dollars in local papers. You can find them also on local internet websites like Craigslist.
I have a family of 6 and my kids are now grown up now but it is still the cheapest way rather than throw your money away on a new dryer or pay to have it fixed. Just thought that I would let you know that. Good Luck. By the way it is very easy to replace the heater relay if you are tech savvy. Good luck.
Feb 21, 2015 | Frigidaire Dryers
Dryer "check vent" light goes on
if air coming out back is strong it might be a bad sensor somewhere
Feb 11, 2015 | Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Electrolux EIED55H Dryer
Heat kick on then off
Check the thermostats. They work when cold but will not reset once warmed up.
Eric
May 27, 2009 | Kenmore Dryers
HEAT FLAME COMES ON FOR ABOUT 10 MINUTES AND THEN GOES OUT
Look inside the door and get me the model number. May be the gas control solenoids need replaced. Let me know, Sea Breeze
Mar 22, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
865 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
