I AM IN S/A. IF I HAVE THAT DETAILS ....WHERE DO I START LOOKING. ANY HELP OUT THERE???
CAN YOU GIVE ME A COUPLE OF OPTIONS.....AS TO WHERE I CAN START SEARCHING. I HAVE THE DATES OF BIRTHS, EST DATE OF THEIR DEPARTURES, NAMES, SURNAMES, MAIDEN NAMES, ADRESSES WHERE THEY LIVE BEFORE THEIR DEATHS?????
Re: I AM IN S/A. IF I HAVE THAT DETAILS ....WHERE DO I...
Main city librarys in S/A
capital city government departments S/A
census records
births deaths marriage records offices
cemetery when open..... have grave site directories
electoral /voting roll archive centers
ancestry .com is world wide http://www.ancestry.com/
When asking for a solution to a problem make sure to give as many details as possible. Saying the bike wont start is not a good description. Give details of the bike......ie: year, model, carbed or fuel injected, this makes a big difference, is the starter turning, is the motor turning, ect....be precise.
Parts Finder YAMAHA OF LOUISVILLE LOUISVILLE KY 502 254 1188 go to this site and select yamaha then type in YZFR1 2001. It will give you a couple different options to choose from. Since you didnt give your exact model thats the best i can do. Hit search then select assembly on the next page and find what your looking for if it doesnt help call the nearest yamaha store to you and they will be able to help but you need the exact model.
Are you talking factory recovery options, or a system recovery.if your looking to do a factory recovery when you start your pc then you have to press either f10 /f11 or f12[ different for different brands].keep pressing till factory restore comes up start as soon as you turn on pc. to get into the factory restore. if you do not have factory restore on your pc you must us the disk that came with pc.. IF YOUR LOOKING TO DO A SYSTEM RESTORE GO TO START SEARCH AND TYPE IN SYSTEM RESTORE AND FOLLOW PROMPTS. need more help give me a holler you didnt say what your running or why you want to restore. glad to help you out.Let me know if i can be of more help to you..
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driver check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall hope this helps
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps
Hi Bob, if it is any help, some dude is selling a complete kit (friction discs only) on ebay(click) at the moment
Or dial up your year and model here to get a full listing of OEM parts numbers.
Hope this helps you. Couple of options at least. If it is npt what you are looking for, hit me back. Cheers
regards
robotek
usually the options are located on the software of the scaner or on the menue you need to provide the name of the scaner so we can provide the details, every scaner comes with a special software and when you start the software it give you on top many choices or on a menue then you click on options and set up your unit. hope that help without any more details
Re boot into safe mode (by pressing/tapping F8 key on boot before Windows begins to load), then select "Safe Mode" from the options provided and run a full virus scan with an updated anti virus program to attempt to eliminate a threat.
Please give more details and/or an explanation of "now i can not acces anythig"?
