Kitchen Appliances - Others Logo
e
elaine mazepa Posted on Jun 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rival seal a meal does not vacumn the air out when it is sealing. what is the problem and how do I fix it
R.A. Ellis
Level 3:
  • Master 12,731 Answers
  • Posted on Jun 07, 2016
R.A. Ellis
Master
Level 3:
Answers
12731
Questions
Helped
2613482
Points
59176
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Gadgets vs107 top and bottom rival seal a meal
ind helpful customer reviews and review ratings for Seal-A-Meal VS107 ... Also, you don't have to search for Rival bags..any 5-mil vacuum seal bag will ... Two things, you have to get the top of the bag straight and flat for it to make the seal. ... I checked out lots of different brands before deciding to buy this lower cost model.
2helpful
Nedd the new tape for a seal a meal machine, rival
dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
1helpful
2answers
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
It may be that the gaskets are faulty. Vacuum will keep running trying to draw air out before sealing. If that is your problem I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012). this part is not listed in the seal-a-meal website, only available by calling.
2helpful
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
2helpful
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Top Rival Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
