Baby Gear Logo
kasey jones Posted on Jun 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a quinny zapp xtra last week was broken and i got a new frame and they have tp different signs on the frame where the number 3 clip it on the plastic how can i tel if one is fake or not
Dorel UK
Level 3:
  • Quinny Master 1,637 Answers
  • Posted on Jun 05, 2017
Dorel UK
Quinny Master
Level 3:
Answers
1637
Questions
0
Helped
453518
Points
2410
Hi - The design of Quinny Zapp has changed over time and a new product may have some differences to an older product.
Speak to your retailer for verification of a genuine Quinny product.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Sep 21, 2008
SOURCE: problem with zapp seat
There are two blackclips on the top inside handles pull these gently to loosen the seat cover. Then repeat on the bottom. You will also have to unbutton the back of the seat (there are two black straps) then half fold the buggy and pull the seat towards you. Its a bit niggly and frustrating but does eventually come off.
Anonymous
  • 3 Answers
  • Posted on Nov 02, 2010
SOURCE: I need to buy qunniy zapp xtra parts. Have lost
Tel. 1-800-951-4113 Include the model number and manufacture date (indicated on your Zapp).
macnutz
Stephen Faulkner
  • 541 Answers
  • Posted on Nov 12, 2010
SOURCE: Please can you tell me
This site has most of the Quinny manuals
www.karlisles.com.au/baby_repairs_spares/instruction_booklets
Dorel UK
Dorel UK
  • 1637 Answers
  • Posted on Nov 10, 2011
SOURCE: Adapters for quinny zapp xtra have been lost on
Good Afternoon
Replacement recline adaptors can be ordered via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 25GBP and if ordered direct there will be 3.99GBP p+p charge.
Anonymous
  • Posted on Dec 07, 2011
SOURCE: how do i attatch the quinny zapp xtra seat to the quinny zapp frame
Yes the new seat unit can be used with old zap.You remove the fabric seat (look on u-tube if you don't know how)the new seat unit then fits on to frame via the addapters that come with the xtra seat unit, at the point where the car seat addapters fit.There is a large push button on the top of the seat unit which you push in to recline or sit up the seat, and a little one too next to it, that needs to be pushed away from the larger one, while you hold the large button down when you want to remove the seat unit.I found fitting the xtra seat very easy.To fold the zapp you Must remove the entire seat unit as it won't fold with it on, unlike the old one.
Does Quinny carrycot bt042 goes with Quinny stroller zapp Xtra ?
Hi Yeska
No the Quinny Zapp / Quinny Zapp Xtra chassis is not suitable to use with a carrycot. Due to the lightweight and short wheel based nature of the Zapp / Zapp Xtra chassis design the use of a carrycot is dangerous as it may cause instability / tipping.
The Quinny Zapp / Quinny Zapp Xtra chassis can be used with a Maxi Cosi Pebble or Maxi Cosi CabrioFix carseat but not a carrycot.
Nov 27, 2013 • Baby Gear
1helpful
Quinny Zapp stroller with folding seat
Hi David
At the moment the Quinny Zapp Xtra with folding seat unit is only available in the USA.
If you are in the USA please contact [email protected] to ask them about compatibility between the products you have and the new Quinny Zapp Xtra folding seat unit.
If you are not in the USA we must advise you not to attempt to combine your products with a USA Quinny Zapp Xtra folding seat unit as the products have not been tested or approved in combination.
Quinny zapp xtra 2012 bumper bar
Hi
The bumper bar accessory simply clicks into place on the seat frame of the Quinny Zapp Xtra 2012 and 2013 model.
It is not compatible with 2011 model Quinny Zapp Xtra so please confirm the unit you have is compatible.
If you confirm it is compatible and still have difficulties please contact your retailer.
Quinny zapp xtra button stuck?
Hi
The chassis needs to come to Quinny engineers for inspection / repair work required.
If you're in the UK and the Quinny Zapp Xtra is under 2 years old please contact your retailer with proof of purchase under standard warranty terms and conditions they can make arrangements for it to come in for inspection / repair work required.
If you're in the UK and the Quinny Zapp Xtra is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss chargeable inspection & repair work required.
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab for the enquiry to be sent to the customer care team in your country who can assist further.
Does the new quinny zapp extra hood fit onto the old style zapp? Or any other quinny hood? I don't mind removing it before folding.
Hi
No the new Quinny Zapp Xtra sun canopy is part of the seat fabric.
If you wish to turn your standard Quinny Zapp into a Quinny Zapp Xtra you need to purchase the Quinny Zapp Xtra seat unit as an accessory from your local retailer as it will have the seat frame and the adaptors required to fit it into the chassis you have.
Visit www.quinny.com to find your nearest retailer.
Replace broken quinny zapp hooks?
Hi
The clips on the standard Zapp fabric for it to be inserted into the chassis and attached correctly are not available as separate spare part items. It would be a case of replacing the seat fabric.
Where can you get the zapp xtra with 4 wheels ?
Quinny Zapp 4 is a USA specification model specifically designed, tested and approved under USA standards.
It is a completely separate product from European model Quinny Zapp 3 and it is not possible to alter a Zapp 3 to become a Zapp 4.
Quinny Zapp 4 model cannot be sold outside of USA as it has not been tested or approved under other countries standards for sale of wheeled nursery goods.
2helpful
2answers
How do i attatch the quinny zapp xtra seat to the quinny zapp frame
1helpful
We have a quinny zapp extra and the little round part that attatches the pram seat to the frame base was lost in the airport last week - is it possible to but a new set please ? x
Good Evening
You can order a set of replacement recline adaptors for your Quinny Zapp Xtra via your local Quinny retailer or direct with our customer service department on 01284 413 141 Mon-Fri 8.30-4.30. They are RRP £25 with £3.99 p+p if ordered direct.
May 21, 2011 • Baby Gear
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
