SOURCE: washing machine after water load the drum
must check water level device,if You do not know what is this or where is on machine then call a service.Maybe is hose is precipitate from device.
SOURCE: installed new beko WM5140s washing machine. Son
Normally transport screws are at the back of machine, but some machines have polystirin packed inside them. To remove this you mormally tilt machine and pull them from bottom. Just a note, I resently installed a machine for a friend, the drum was out of balance, this was a fault on the machine, so if this problem is not resolved dont just think you are at fault as it could be a major problem on machine. Good luck and I hope this will help you to resolve the issue.
SOURCE: Wash cycle taking over two hours
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: how to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
