Two filters /check valve have blown in half at the seam one in service for 1 year and its replacement. can the pump be putting too much pressure?why is it always me with the strange problems?
Well answer to your question , yes they do have lots of pressure (60 to 110 psi) that's a lot !!
second the device that its job is to regulate the fuel pressure is the fuel pressure regulator , now more modern types use a sensor and a separate pressure relief device but in your case its all in one device , follow your fuel injectors fuel supply rail to there end !! there your gonna see a black device with three lines run to it (one is fuel input, one is fuel return to tank, one is manifold vacuum ) all these hoses need to be ck for holes/cracks/kinks/ b4 you replace the regulator
