Question about Haier Refrigerators
Plugged it in it worked great for the first few hours, but then it didnt stay cold. kept on about week, stayed spotty, getting cold, and not. im broke, need to fix'r myself, i just dont know how.
Model # WN03V 3.3CU FT SERIAL # - 33VT1207-002311 PURCHASED USED
  • Haier Master
  • 4,656 Answers
Do you know how to jump the thermostat wires? The problem could be the start relay, thermostat or a Freon leak. Does the compressor get hot while running? Does the compressor stop and start frequently?
APPLIANCE 911
Posted on Jun 04, 2016
Testimonial: "i have never worked on a fridge before, so i dont kknow how to jump the thermostat. and tips on how to do that? i know its not a freon leak, due to it being factory sealed, it would take a lot for that to be the case. it get a bit on the warmer side, so i try to not keep it so close to the wall. and yes it will start to run, and then stop. sometimes it sounds like its running, but its not gettting cold."
  • 1 more comment
  • Nicholas Cohen
    Nicholas Cohen Jun 04, 2016
  • John Tripp
    John Tripp Jun 04, 2016
    Factory sealed leak all the time yet I don't believe that is your problem.
  • John Tripp
    Feel the top of the compressor to see if too hot to keep your hand there and get someone to show you how to jump the thermostat wires to see if a defective thermostat. Testing that way can tell you if the thermostat is bad by causing the compressor to run all the time.
SOURCE:
84yamaha fj1100 20,000 miles. Everything ran well when i bought it a couple weeks ago, then it didnt start for about 3 days straight and one morning it fired right up. i had a tender attached cause i kept...
inspect all wiring for flaws and corrosion-new relay will probly help-its up by the batt-new brushes in alternator also--have battery tested--buy a clymer manual
May 29, 2011 | Yamaha FJ 1100 Motorcycles
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not cold enough
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Dec 29, 2008 | Frigidaire FRT21H8 Top Freezer...
I pod only turns on then shuts down and comp doesnt reconize it
Your battery is dead!!! Try to recharge with USB adapter!!! If that doesn't work you need to change battery. Give me some spec. about your MP3!
Jan 25, 2008 | Apple iPod nano 3rd Generation
Zenith R56W36 56..... Wont stay on
seems like aging problem , your best bet its to replace the deflection board, let me know if you need more info
Jun 10, 2007 | Zenith R56W36 56" Rear Projection...
Refrigerators Logo
73 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
