Golf Logo
Cindy Willadson Hudgens Posted on Jun 03, 2016
Got new batteries but chRger won't charge them
  • Cindy Willadson Hudgens
    We have six batteries in our. Is there a reset or something like that? The batteries go frozen back in 2004 and we never got them replaced until this month. The charger is the original one for the golf cart.
Johnny
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Jun 03, 2016
Johnny
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
14262
Points
96
Battery CHARGERS must have the correct batteries (NiCd or NiMH), plugged into a working outlet, and the batteries much be in a specific position. IF 2 batteries are in a 4 battery charger, and they are both in the center, It won't work. If 2 batteries in a 4 battery charger on the left, it will work if they are both securely positioned.
Once in awhile you get a non-working charger. Make sure you have the right charger with batteries. A few have a switch for NiCd or NIMH.
1helpful
I have a Nokia c301 that won't turn on..have changed batteries still wont power on....
Faulty main board junk it.
Are the batteries charged?
Your chrger socket on the phone may be damaged.
Charge the batteries outside th ph0one and try.
If it still doesnt work the phone has a failed main board.
Not economical to repair - junk it!
Froze and wont charge or open up. It shows battery but not charging stays frozen. help Please!
Feel your chrger, Is it warm to the touch? If it isnt, you may need to replace it. Can you turn the tablet turn off and can you turn it back on? What is the level of the battery?1/2, 3/4?
It will only come on when its charging....when ever its off the chrger it wont turn on
Unseat your battery and then re-seat it. If that doesn't work then you may need a new battery.
I have a 92 camaro rs tbi and the alternator and the battery went bad and i just replaced them 2 days ago and now the battery is dead again and after i charge the battery it still wont hold a charge the...
take it back they have to replace it,they either have a 60-90 day warrenty also see if battery cables are tight.if you have a chrger see if battery holds a charge.
Not sure if jet 3 is charging
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
New battery will not charge on inspiration 6000 works fine when plugged in?
a hundred to 1 your chrger is ****. Though it will still keep it powered on....it doesnt have enough connection to give it a full charge. I had this same laptop and with the same problem. go to ebay and buy a new charger for 15 bucks and your problem is solved. In the future always try the charger first ...they are always cheaper than a new battery!
My c905 battery charges and empties after about half way
One thing i have thought of is the problem could be with the charger.
The best thing to do is, take into your dealer explain your situation ask to see if a new chrger would help.
I presume your still on warranty , then you could get a replacement.
Hope its helped!
Charging prints are damge
replace charge pins or buy universal battery chrger
Jul 12, 2009 • Cell Phones
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
