Question about Camping, Backpacking & Hiking
User manual for veeki rechargeable flashlight
How to change from dim to bright
    Habit-Forming:
    New Friend:
  • 70 Answers
You half push the on off switch it changes between the MODES 1. low
2. medium
3. High
4. Strobe
5.SOS
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Posted on Jun 29, 2016
SOURCE:
Why does my 2d mag flash light stay dim
Check for corrosion at the bulb, or the spring or the switch. This happens sometimes when batteries leak internally.
Oct 20, 2014 | Other MAG-2D - Maglite Small Head 2 D-Cell...
Monitor is very dim
Just go to windows button search for battery then
you will see like this and check your screen brightness is it full
Dec 04, 2013 | Computers & Internet
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
I can't find the user manual for Vector flashlight/spotlight model # VEC 1138.....where can I get this? Thank you
Here is the manual.
Please give four thumbs up for my response if it helped!!
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC1138%20MANUAL.pdf
Aug 25, 2011 | Vector 1 Million Rechargeable Spotlight
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
Screen is dim and I cannot fix it. I used a
It has a 12 volt lamp in it that illuminates the display screen. It is not a user serviceable part. You will need soldering skills and tools to replace it.
Apr 28, 2010 | Philips AJL308 USB/SD radio alarm clock
Gateway 900g monitor will not turn on. When the power button is pushed, the blue light just flashes.
Check the monitor with a known-good cable. Look for bent pins in the connector to be safe. Next, have a bright flashlight handy. Dim or turn off the lights in the room. Turn on the flashlight and hold it very close to the screen. Look around the screen carefully and try to see a dim image in the display--if you can see the computer image, it means a problem exists with either the power supply section or, the actual display section. What is happening in this case is two(2) extemely thin, very bright, fluorescent tubes are failing to ignite. These tubes are usually laid top and bottom on the larger monitors, out of view by the user. Their light is transmitted through a series of specially designed plastic sheets which reflect against a shiny back sheet--this gives you the crisp, bright whites and colors in the image. Warning: if repairable, this is a very involved repair. Have purchasing a new monitor in the back of your mind if you send the unit out to a repair facility for a quote.--Just my thoughts--Rick
Sep 21, 2009 | Computers & Internet
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Camping, Backpacking & Hiking Logo
539 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
