The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
Hi
I found your error code and suggested remedies here: Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
The purpose of writing this letter is to inform you that my machine got some technical problem. We unable to solve this problem since last year.My machine is Konica R1 DP-1000E. And the machine always show the words "The machine error printer no: err-D1301-0 link with processor failed." We are here request for your technical help If possible, please contact my cellphone +673 8896003.
The F_1error is related to faulty control module.This parts fails and stop working causing this F-1 error code.In some cases pressing pause/start button 4 or 5 times help4ed to solve the problem for some time but not permanent solution.------------To see how the control module looks click this link directly:--http://www.repairclinic.com/PartDetail/Control-Module/1469076 -----------------F-1 error is under a recall by whirlpool carbio washer.There are many others to getting this problem.
Call whirlpool.1-800-253-1301------------------------ Click this link directly and see what others have mentioned for this same error code:---http://www.fixya.com/support/t423788-whirlpool_cabrio_washer_error_message
This should help.Thanks.Helpmech.
Code F51-2 at start-up. Description: Code F51-2 at start-up. Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
