2006 Opel Corsa 1.4 Logo
D
Derrick Ngomane Posted on Jun 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i bypass a sensor of an opel corsa utility 1.4 2006 model?
The car broke the timing and crankshaft pulley but when i replaced them i found out that where you put them is bent so when the engine the crankshaft pulley it not moving straight and it moves away from the sensor, so I want to know how can I bypass it?
Richard Faber
Level 3:
  • Opel Master 1,444 Answers
  • Posted on Jun 03, 2016
Richard Faber
Opel Master
Level 3:
Answers
1444
Questions
Helped
379399
Points
5288
If you bent the crankshaft and are talking about the crankshaft sensor can't bypass it the car will not run without it
2answers
2answers
Crankshaft torque Opel Corsa 1.4 bakkie utility 6w engine
You need a Service Manual, as the details are not available online apart from trick/scam sites
https://www.google.com/search?q=opel+corsa+1.4+utility+6w+service+manual
2helpful
Opel corsa baklie 1.6 sport 2007di engine light dont com on and dont haf sperk
the signal from the crank angle sensor thats mounted against the block pointing to the crank pulley is what tells the ecu that the engine is turning and to provide spark and injector pulse
so your possible problem area is the ecu
also check the ecu harness plug wires and pins
make sure the crank angle sensor is plugged in
1helpful
2005 Opel Corsa lite switches off with irregular revs
Front right lower side is the crank sensor ,in line with the crankshaft ,could be this playing up although i have had many problems with this type of engine ,one problem is the computer bolted to the engine ,seem to suffer heat fatigue ,another problem i cannot explain is it just will not start and for this i fit a crank sensor from the earlier version with the toothed front pulley and support then cut the wires from the crank sensor and run them to the one at the front of the engine but they are polarised on the wires so if it doesnt start reverse the wires to the crank sensor ,Now no doubt iam wrong as ever but i do think that the crank becomes magnatised and its affecting the sensor so by moving it to the front pulley it eliminates this problem .
2answers
Opel corsa 1400 has no idle
This car is a one point injection motor.So there is a screw
to adjust the revolutions. If you cant find it ask a mechanical
to show you,
3answers
Torque settings for Opel Corsa Crankshaft and Cylinder head
Hi I have a Opel Corsa utility 1.7D I am doing the hole engine over but I need the setting for it 2000modle Corsa and the engineers are rebuilding the crank is that okay or risky
2helpful
3answers
1helpful
2answers
Hi, i have a 1997 OPEL CORSA, it has a 1.4 petrol ecotec engine i went to start it but it wouldnt spark at all. i have tried replacing the coil ack adn the distributor cap but it still isnt working. s
ITS AT THE BOTTOM OF THE ENGINE NEAR THE CRANKSHAFT PULLEY, IF YOU STAND IN FRONT OF THE CAR FACING THE WINDSCREEN , ITS ON YOUR LEFT , IT ACTUALLY READS OFF THE PULLEY TOOTHED WHEEL, IT FITS ONTO A BRACKET HELD BY A TORX BOLT , ITS ALSO VERY CLOSE TO THE PULLEY AND HAS A CABLE CONNECTED TO IT
Top Opel Experts
NOEL
NOEL
Francois Havenga
Francois Havenga
Are you an Opel Expert? Answer questions, earn points and help others
