Everstar Portable Air Conditioner MPK-10CR Logo
Larry Barrett Posted on Jun 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit will not power on. Green light on the power cord indicates it is getting power. also tried different receptacles.
Ran for about 5 minutes and noticed an electrical smell. Then quit.
Edward Shelton
Level 2:
New Friend:
  • Expert 98 Answers
  • Posted on Jun 02, 2016
Edward Shelton
Expert
Level 2:
New Friend:
Answers
98
Questions
0
Helped
36005
Points
223
Servo is probably fried. Check with a ohm meter for continuity.
Mike Rykhus
Level 1:
New Friend:
  • Contributor 25 Answers
Mike Rykhus
Contributor
Level 1:
New Friend:
Answers
25
Questions
Helped
8286
Points
41
If you noticed an electrical smell (like something was overheating), you may have a compressor lockup, or a fan lock. If you know a good, and knowledgeable handyman, he should be able to troubleshoot the unit quickly. But if it is the compressor, repairs could cost as much as a new unit.
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
10helpful
2answers
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Brand new freezer not starting
You may have plugged your freezer into a bad receptacle, which is not providing the proper voltage. (usually due to a loose wire or bad contacts in the receptacle.) After letting the unit sit for at least 10 minutes, plug it into a different outlet (preferably on a different breaker). You can use a heavy gauge (like 14 or 12 gauge) extension cord for the test. If it starts and runs, fix your original receptacle / breaker / wiring. If still the same results (compressor not starting), call for warranty service.
5helpful
Headset CS50
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
1. Return the headset to the
Headset Docking Cradle
2. Press and hold both the
Speak Volume Adjust Buttons (+/-)
on the back of base unit for a
minimum of 5 seconds. The
Red Power Indicator will then
flash
3. Press and hold the Headset
Mute Switch (black button on top
of earpiece) for a minimum
of 5 seconds. The On-line
indicator (green light on boom)
will then illuminate.
4. Subscription completion is
indicated when the Power
Indicator is fully illuminated
and the On-line Indicator is
extinguished.
5. If subscription fails within 2
minutes the headset will return
to the un-subscribed state.
1helpful
Toshiba 400cs does not boot
Removed battery and plug in AC cord. Unit booted up and ran fine.
3helpful
3answers
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Lost power- will not come back on
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord. If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable. If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit. Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
Top Everstar Heating & Cooling Experts
Paul Carew
john h
Are you an Everstar Heating and Cooling Expert? Answer questions, earn points and help others
