Gareth, save your self a lot of aggravation and call a local lock smith, they can fix this problem fairly quickly and replace the key. I do not believe it will be too expensive either. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
7 tricks to get broken key out yourself any lock or key
How to remove broken key from the ignition
How Much Does Locksmith Cost CostHelper com
