Question about Honda Garden
Type of hydraulic oil for Honda GC160 pressure washer
What type of hydraulic oil to use in the Honda GC160 pressure washer
    Sergeant:
  • Honda Expert
  • 439 Answers
  • 10w30 hd motor oil
Posted on Jun 21, 2016
SOURCE:
joecoolvette
  • 5660 Answers
SOURCE: will crank but runs rought them cuts off
Sounds like water in the fuel, or old gas. Drain the tank into a suitable waste container. Drain the carburetor float bowl, and the fuel line. Reattach the fuel line, and clean the float bowl out. (BE careful of the float bowl gasket!)
Replace the float bowl, and add fresh gasoline. I would use at least 91 octane. (NO gasohol!)
You may have to run it for a while to straighten it out.
Also remove the spark plug, and see if deposits have built up on the center and side electrode.
Todays gasoline has all kinds of additives in it. Some are designed to keep deposits from building up so much. (In truth, all gasoline is the same)
These small engines, usually require changing the spark plug at regular intervals.
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
  • 16 Answers
SOURCE: I have a Honda gc160 5.0 pressure washer. All
needs new pump
Posted on Oct 03, 2009
  • 623 Answers
SOURCE: Pressure washer with Honda Engine GC160 only run
The carb is clogged. It needs to be cleaned, or replace. Keep in mind some of the carb passageways are as small as a human hair so they are difficult to clean which is why I mention replacing. You can try using carb cleaner etc in the gas, but I don't think it will work if you need the choke that much.
Posted on Apr 30, 2010
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
Aug 08, 2016 | Honda Garden
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
Oil leak appears to be from pump, not engine, GC160. What oil and how much should be replaced. what might be source of leak
some pumps have a side glass and oil should be half of side glass and depends on manufacture oil is different if general pump you can use 30w non detergent
Aug 24, 2010 | Honda Pressure Washer PSI 3000
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
May 27, 2010 | Honda Pressure Washer PSI 3000
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer oil
SAE 30, or 15W-40
Jul 31, 2009 | Honda Garden
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
494 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
