Everstar Portable Air Conditioner MPK-10CR Logo
Ashley Marchesi Posted on May 31, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It was flashing red like the water was full. I emptied the water, put the container back in and it was still flashing. I tried to shut it off, but it wouldn't shut down.
Finally I unplugged it, but when I turned it back on it was doing the exact same thing. Now it wont turn on at all.
Caleb Brunson
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Jun 06, 2016
Caleb Brunson
Expert
Level 2:
New Friend:
Answers
54
Questions
Helped
24220
Points
130
When you unplugged it you broken the circuit which is what it does when pan is full of water to get you by turn the two wires together to make it think the switch is made
1helpful
2answers
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
3answers
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
What does it mean when the green LED light and the alarm light are both permanently on at the same time. There is a full tank of water, service door has been opened and shut and the dreg drawer is empty...
Hi, Turn off the machine and turn back on again. If both lights are permanently on that means you need to empty the dreg tray. Pull out the tray and wait until the red light start flashing, then put back the tray, the red light will go off.
Another meaning is when you press the coffee button and see the red light came on, that means the grinder motor is not working. Hope it will help.
1helpful
2answers
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
1helpful
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
2helpful
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
11helpful
2answers
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
2helpful
3answers
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Top Everstar Heating & Cooling Experts
Paul Carew
john h
Are you an Everstar Heating and Cooling Expert? Answer questions, earn points and help others
