So i tried to get my mouse to work on my new monitor. I tried to go to the menu thing and Then on the 3rd i Saw something with Hdmi so i tried to Press that Then my monitor Got to Black and i cant acces the menu thing to go back to auto. How do i now go back to auto again?
SOURCE: Native Reolution?
first, check outlet, make it sure that power is on the appropriate voltage. then your UPS and voltage regulator also. try to check all button switch and your video card
SOURCE: Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
SOURCE: Computer monitor screen stays black
check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
SOURCE: my volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
