Hi. I have an older 1960's horse tiller. I need gear oil for the transmission. All I can find is Traveller multi purpose gear oil, API service, GL-5. Is this okay to use? Thanks, Bill
Hi. Thanks for your question.Genuine NISSAN engine oil*2. ACEA C3 and C4 LOW ASH HTHS 3.5, Viscosity SAE 5W-30*2. Genuine NISSAN Engine Coolant or equivalent in its quality*4. Genuine NISSAN Matic S ATFrecommended*5. Genuine NISSAN Manual Transmission Fluid (MTF) HQ Multi 75W-85 or API GL-. 4. You can visit https://www.reliable-store.com and download the entire service manual for better understanding of replacement method. It has all the information along with the diagrams which are really helpful. Good day!
Troy-Bilt says that if adding a few ounces only, use GL-4 or GL-5 gear oil. If refilling an empty transmission, use GL-4, with a viscosity of SAE 85W-140 or SAE 140. Best regards, --W/D--
Standard differential gear
API GL-5, viscosity SAE 80W-90
Limited-slip differential (LSD) gear; Use only LSD gear oil API GL-5 and SAE 80W-90
if you meant front differntial
Transmission Fluid Dexron III, Mercon or API GL-4 viscosity SAE 75W-90
if you meant transfer case
Engine Oil SE Class SAE 10W40, 10W50, 20W40, 20W50
w/Filter Change 4.0 liter
No Filter Change 3.5 liter
Level On center stand, wait 5 min, middle of window Left side of engine case cover
Final Gear Case Oil
Above 5°C API GL-5 SAE 90
Below 5°C API GL-5 SAE 80
Capacity 0.2 liter
Level Mcy vertical, to bottom thread of filler cap hole left side of rear wheel
You can use-
Motorcraft MERCON Multi-Purpose (ATF) Transmission
Fluid XT-2-QDX
MERCON®
Alternative Transaxle Fluid - SAE 75W90 Gear Oil
F32Z-19C547-MA
API GL-4 You are seeing that right, one instance they call for 75W90 and the other it is ATF. It is ok to run either, 75W90 will give you smoother shifts and less noise.
This transmission is filled through the VSS (Vehicle Speed Sensor) hole.
