Question about Lacrosse La Crosse Technology Atomic Clock With Outdoor Temperature And Weather Forecast
How do I reset the clock to correct time? - Lacrosse La Crosse Technology Atomic Clock With Outdoor Temperature And Weather Forecast
  • 1,682 Answers
how do I reset the clock to correct time? - 26208271-feum23phdkkiz3bf0e0pm1n0-4-0.png
Posted on May 29, 2016
SOURCE:
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Clock is not correct
to reset your clock on your computer, do the following
1.click the START as if logging in, in the opened dialog option, 2.click CONTROL PANEL , in the control panel items locate DATE & TIME, and click on that, Now, you can set your time and date, i hope this help.....have a great day.
Jan 20, 2014 | Facebook Social Network
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Sep 11, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
How do you correct the daylight savings time problem
If your clock changed to DST late then it's hardwired for the old changeover schedule - and there's no way to reprogram it. All you can do is reset the time manually or change your time zone setting to "fool" the clock into displaying the correct time. Either way, you're going to need to reset the clock as many as four times a year to keep the correct time. The ultimate solution is to replace the clock with one that's set up for the new DST schedule.
May 08, 2010 | Emerson Smartset Clock Radio
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
Honda VFR800 Fi 2000 W Reg LCD clock problem
The problem is usually a weak battery. When cranking, it pulls down the system so much that the clock resets. Try puting the batt on a charger and start the bike to see if the clock resets with a steady feed of voltage.
May 17, 2009 | 2005 Honda VFR 800
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
hour setting is announced.
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
minutes setting is announced.
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Lacrosse La Crosse Technology Atomic Clock With Outdoor Temperature And Weather Forecast Logo
821 people viewed this question
Top Lacrosse Measuring Tools & Sensors Experts
micky dee
Andrew Taylor
Andrew Taylor
Are you a Lacrosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
