Video Cameras Logo
kamran usmani Posted on May 29, 2016
No audio video
Video in lcd but no output vide o
1 Related Answer
Anonymous
  • 30 Answers
  • Posted on Feb 07, 2010
SOURCE: No audio output when playing dvd on PS3, although
Are your speakers working properly?
-K.R.
1helpful
Antenna's for micro hi-fi component system
you can buy antennas on amazon.com or at radio shack.
1helpful
2answers
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
1helpful
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
2helpful
4answers
I don´t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Using Cable Box
two cords audio/out audio/in
vide/out from the cable box to the recorder video/in
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
