Need more designs to embroider. What is the best way to purchase more designs and how do you get them to the machine to embroider them.
SOURCE: Janome 300E Memory Craft reading .sew and .jef
Hi what you need to do is change the format as it is only able to process the one format.
What you can do is search online for software that converts the formay for you most of these sites are free so have a look you whould find plenty.
Alot of people have this problem but changing the format get round this ok let me know if you need further assistance ok
SOURCE: need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
SOURCE: Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
SOURCE: I have purchased a Janome 9700 embroidery machine
Since you are able to view them from the ATA (Compact Flash) card on your computer and the designs are in *.jef format you should be able open them on your machine. Make sure you have selected to view designs from the ATA memory card and not the ones stored on the machine or from the External Card Reader box.
There is an additional program called Customizer that you can import designs, edit, and transfer them to your ATA card. Mine was part of my package deal when I purchased by 9700.
SOURCE: How to I randfer embroidery designs on a flash
If the designs are already on a formatted* flash drive and in the format of the embroidery machine and the embroidery machine has an USB Port-A receptacle, you just plug it into the machine.
If the flash drive was not formatted for the Janome, then this may help - http://janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=639
Get a new flash drive and start fresh.
Create a folder on the PC's hard drive and name it Embroidery Downloads and copy or send from the flash drive you now have. Keep the flash drive as a backup.
After you format the new flash drive, you can then copy as needed from the Embroidery Downloads folder. Just do a couple.
